Cutting Laminate Floor In Place Without Chipping Edges - Flooring - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 12:55 AM   #1
Rewards Points: 152
Cutting laminate floor in place without chipping edges
I have laminate floor laid around a half-circle hearth where a wood stove used to be downstairs. I'm installing a new wood stove that'll need a bigger hearth.
Planning on cutting the laminate floor to the proper, rectangular size and tiling within. Question is, what can I use to cut the floor? Whenever I've laid laminate before, the saw always seemed to cause chunking/chipping on the cut edge no matter how slowly I cut (which I could then hide under the baseboard).
Any tips?
Thanks!
burnt03 is offline   Reply With Quote
Old 04-05-2012, 01:03 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Oscillating tool.
http://www.diychatroom.com/f29/oscia...i-tool-120729/
sublime2 is offline   Reply With Quote
Old 04-07-2012, 01:06 PM   #3
rkg
Originally Posted by sublime2 View Post
+1 on this - I picked up one of these and a "half moon" blade to make a couple of difficult cuts in some underlayment that had to come out (it was cheaper than renting a toe kick saw a couple of times), and I've found it to be incredibly useful for all kinds of other stuff as well. Horrible freight usually has one "on sale" for 18.99 if you can find the coupon.
Good Luck,
rkg
(Richard George)
rkg is offline   Reply With Quote
Old 04-07-2012, 08:03 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
a laminate blade and a circular saw would be my 1st choice. youll have a hard time making a straight cut with a multi-too. A blade with as many teeth as possible meant for laminate is appropriate.
Millertyme is offline   Reply With Quote
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
Cutting Round Duct in Place stubits HVAC 11 04-29-2010 05:44 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Cutting off 3" of laminate counter top in place 4just1don Building & Construction 3 09-27-2008 10:33 PM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 09:42 PM
