#1 |
underqualified shoprocket
Cutting into the basement floor....
to install plumbing for the basement bathroom.
is there one specific tool that's better/easier/faster than the others in order to get this accomplished. Just go at it with the sledgehammer? or rent something a little more hightech from home depot? any thoughts? |
#2 |
I dont know if Home Depot has them, but can rent a concrete saw to sawcut the slab then use the hammer
#3 |
Contractor
I would cut first and then go to an electric hammer unless you need the exercise.
#4 | |
actually, i probably DO need the exercise.
thanks for the advice, i'mme headed to home depot on monday to rent the saw, i'll see how far i get before i decide on electric hammer or sledge Quote:
#5 |
Carpenter
I used a small electric floor breaker. The saw will give you a straight cut if used first. The downfall is that the dust will fill your house. Bottom line, is it's your call.
Terry To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Contractor
Starting out with impact tools without creating margins could cause cracks. Even creating the margins does not eliminate this possibility although it certainly lessens it.
#7 | |
Carpenter
Cutting into the basement floor....Quote:
#8 |
Contractor
Terry, I've never heard of a 2" slab. 4" is minimum here. An impact tool creates an impact cone that will be wider at the bottom than the top. If the slab is stressed from setteling it often does not take much to generate a fracture.
#9 | |
Carpenter
| Display Modes | |
| Laminate or vinyl on a concrete basement floor? | pjpjpjpj | Flooring | 36 | 09-03-2012 02:37 PM |
| Basement floor reno | D.RED | Flooring | 1 | 06-21-2006 03:20 PM |
| Uneven\Buldging Cement Basement Floor | SSandecki | Flooring | 5 | 12-20-2005 06:06 PM |
| cutting a concrete basement floor | Rembrandt | Introductions | 1 | 10-23-2005 01:58 PM |
| Cutting into the basement floor | hallbum | Remodeling | 3 | 10-07-2005 11:14 PM |
