-   -   Cutting into the basement floor.... (http://www.diychatroom.com/f5/cutting-into-basement-floor-1113/)
hallbum 10-07-2005 07:24 PM
to install plumbing for the basement bathroom.
is there one specific tool that's better/easier/faster than the others in order to get this accomplished.
Just go at it with the sledgehammer? or rent something a little more hightech from home depot?
any thoughts?
'Andyman 10-08-2005 07:32 AM
Breaking concrete
I dont know if Home Depot has them, but can rent a concrete saw to sawcut the slab then use the hammer
Teetorbilt 10-08-2005 07:26 PM
I would cut first and then go to an electric hammer unless you need the exercise.
hallbum 10-09-2005 12:57 PM
actually, i probably DO need the exercise.
thanks for the advice, i'mme headed to home depot on monday to rent the saw, i'll see how far i get before i decide on electric hammer or sledge
DecksEtc 10-09-2005 10:13 PM
I used a small electric floor breaker. The saw will give you a straight cut if used first. The downfall is that the dust will fill your house. Bottom line, is it's your call.
Teetorbilt 10-10-2005 06:04 PM
Starting out with impact tools without creating margins could cause cracks. Even creating the margins does not eliminate this possibility although it certainly lessens it.
DecksEtc 10-10-2005 07:23 PM
I do agree with you Teetor. The reason I was able to get away with just a floor breaker in my basement because the floor had only about 2" of actual concrete before the gravel. I guess because of that and luck, I didn't have any cracks develop.
Teetorbilt 10-10-2005 11:47 PM
Terry, I've never heard of a 2" slab. 4" is minimum here. An impact tool creates an impact cone that will be wider at the bottom than the top. If the slab is stressed from setteling it often does not take much to generate a fracture.
DecksEtc 10-11-2005 12:01 AM
Around here the new home builders get away with murder. Yes, they advertise a 4" slab but I can tell you from experience that 2" is about the max. The same goes for the so called 4" of aspault for the driveways that is closer to 2", the advertised 6"-8" of topsoil that is closer to 2" or the crap they slap on the walls and ceilings that passes for paint - I could go on. And don't get me started on the crap they pass off as "decks/railings" - but then that helps drive my business.
