Old 06-22-2008, 12:40 PM   #1
Default Cutting installed tile
I was going to start the installation of my ditra and tile today but im having a problem. I will be installing a heat register on teh floor in the room later on this year. I was wondering how hard it would be to cut a tile that is laid and thinset to the floror to add a heat register to?
simonb is offline   Reply With Quote
Old 06-22-2008, 03:25 PM   #2
Tileguy
Cut the hole now and lay the tile around it.
You don't want to be cutting that hole after the tile is in place if it isn't totally necessary and you are equipped to do so.
Old 06-22-2008, 04:02 PM   #3
Problem is I dont know exactly where it will be cause the joist in the floor. I know it would only affect 1 or 2 tiles against the wall, so i was thinking using a Rotozip with a tile bit and taking my time. Once I am through the tile i can remove it slowly, to preventfrom breaking other tiles, and then use a sawsalls to cut the floor.
Old 06-22-2008, 04:10 PM   #4
Tileguy
You know where the floor joists are now!
Leave out those tiles.
...so i was thinking using a Rotozip with a tile bit and taking my time.
You're kidding yourself there. Those tile bits won't cut floor tile.
Old 06-22-2008, 05:16 PM   #5
Well i wont know where the joinst are until i start my reno in the kitchen, bellow the washroom. The wife wants the tiles in fast enough, I explained the problem with me wanting to add a heat register, so she asked me if I can add it after the tiles are laid.
Whats the worst that can happen if i try to cut them once isntalled? Would somekind of disk grinder work for cutting the installed tile? If i break the tile, is it a big job just to remove that tile itself and replace it, once i cut it to the right size?
Old 06-22-2008, 05:23 PM   #6
Tileguy
Go for it!!!
Old 06-23-2008, 12:15 AM   #7
When installing laminate floor or wood floor, if the tile is on a curve, the installers have to cut the tile straight. I don't know what they use, but it can be done.
HomeDepot23 is offline   Reply With Quote
Old 06-23-2008, 03:14 AM   #8
K&B Remodeler/Tile Guy
angus242's Avatar
Good luck and when you cut the tiles inside, be prepared for a BIG mess
Life will be easier if you plan ahead. I'm just sayin....
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-23-2008, 12:52 PM   #9
I know what you guys mean, I will try to plan ahead and make my register hole before i tile. What about drilling a hole in the tiles? Im installing a bifold door for the storage in teh washroom, and ill need to install that little bracket on the floor. Is drilling 1 or 2 holes in tile very hard?
Old 06-23-2008, 01:04 PM   #10
angus242's Avatar
No but a special drill bit will be needed.
Pictures!!!!!!
http://diydata.com/tool/drillbits/drillbits.php
Angus
My Albums
More On This Topic
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
I’m Lee. I have a degree in architecture and about ten years in the construction field and today we’re doing a fairly ornate countertop in my own house. Both of the countertops are using the basic same colors, but it’s a different tile... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
resetting toilet after new tile installed shotdown Plumbing 10 07-01-2009 12:09 PM
Cutting Porcelian Tile without chips BruceStone Building & Construction 3 02-01-2008 06:33 PM
Cutting installed tiles steve65 Flooring 5 01-29-2008 03:27 PM
Cutting Tile rookie1 Remodeling 9 10-22-2007 06:25 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 04:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
