Cutting Existing Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 10:37 PM   #1
jbook
cutting existing tile
I am putting cabinets next to existing cabinets(same type). I have to cut existing ceramic tile from floor the size of the cabinet baseboard to match up with the existing cabinetry. The existing cabinet was tiled around it not under it so in order for the heighth to be matched up I must cut the tile. My question is what tool and method would be best to do this? Circular saw???
rockybgood is offline   Reply With Quote
Old 11-14-2008, 11:09 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Why not cut the bottom of the cabinets instead?
Jaz
Old 11-15-2008, 12:26 AM   #3
All trades carpenter
Jazz has a good idea there but if you are dead set on cutting the tile I like to use a 4 1/2" grinder with a diamond blade on it. I would try to have someone with a shop vac behind you because it will make alot of dust. Also if you are worried about making a straight cut you might want to go with cuttig the cabinets. It takes a steady hand to use the grinder!
CrpntrFrk is offline   Reply With Quote
Old 11-15-2008, 07:28 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
I would agree, Cut the bottom of the cabinet. its easier and you will not risk the chance of damaging the floor.
Old 11-15-2008, 03:36 PM   #5
Cut the cabinet
I'd cut the bottom of the cabinet.
Last edited by AtlanticWBConst.; 12-03-2008 at 10:50 AM. Reason: Site Rules Violation: Adertising Links Removed From Signature
seanJohn is offline   Reply With Quote
Old 12-03-2008, 10:34 AM   #6
jbook
That was my first thought as well but I dont have a set up to cut the cabinets nor do I have the confidence to cut it precise however I did ask the cabinet maker if they could cut it to my specs and they did so thanks for the advice. I misunderstood them when they rounded my measurement up to 7 foot for standard cabinet size.
Jerry
Old 12-03-2008, 12:27 PM   #7
bradnailer's Avatar
A circular saw with a tile cutting blade would work fine or you could use an angle grinder with a diamond blade. As was mentioned, have the shop vac handy as it will make some dust.
bradnailer is offline   Reply With Quote
Old 12-03-2008, 05:51 PM   #8
jbook
thanks brad nailer however i already solved problem as per last message i sent today. the cabinet makers cut cabinet to my specs and it turned out good.
jb
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Cutting Narrow Tile Pieces MrBill_DIY Remodeling 2 08-17-2008 01:33 AM
Cutting Tile rookie1 Remodeling 9 10-22-2007 05:25 PM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 05:19 PM
