Cutting Dricore Subfloor Panels -- Dimensions - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 07:13 AM   #1
Rewards Points: 1,440
Not sure how many Dricore users are on this forum but ...
I finally decided to use Dricore (or Subflor) chipboard tongue & groove panels for my basement remodeling.
The instructions say to stagger the seams by starting with a whole panel in the corner for the first row, then a half panel followed by whole panels for the next row, then starting with a whole panel for the third row etc.
Does it matter if I cut the panels to stagger the seams at other than 50/50% split, for example starting with a whole (2x2 foot) panel for the first row, starting with a 17 inch panel for the second row, a 9 inch panel for the third row and so on. This way I end up with less wasted material since the last panel on each and every row will be an odd width and I could use the leftover piece from the last panel position on one row to start off the next row.
I do realize that cutting the panels to odd widths will result in cutting through as opposed to between the embossed plastic "feet" on the bottom.
Old 12-06-2011, 09:54 AM   #2
Rewards Points: 13,228
You should be asking DriCore these questions for the real ansewer.
Old 12-06-2011, 10:44 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Optimum strength in the panel installation will be realized by splitting the cut pieces in the center as directed. To re-invent the wheel you should have the blessing of the Dri-Core maker.
XXX
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 09:45 AM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
