Cutting Ceramic Tile With A Scroll Saw? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 12:29 PM   #1
Question
Cutting ceramic tile with a scroll saw?
Hi,
I've started a small tiling project for an entryway and have a few intricate cuts to make. I don't want to shell out for a tile saw and I have 2 more small projects down the road so I would prefer not to have to rent a saw 3 times.
Is there a scroll saw blade made for cutting ceramic tile? If so, what kind and where would I find this?
Thanks!
HandyHunter is offline   Reply With Quote
Old 12-03-2011, 12:37 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by HandyHunter View Post
Hi,
Thanks!
I've never seen tile cut with a scroll saw. It would require a masonry blade, which I don't think they make for a jigsaw, though I could be wrong.
titanoman is offline   Reply With Quote
Old 12-03-2011, 12:39 PM   #3
ccarlisle's Avatar
What's wrong with a 3" carbide blade on your 4" grinder...?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-03-2011, 12:43 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
You can pick up one of those small, cheap wet saws for about what it would cost to rent a big one for one day.
That and a diamond drill bit off of ebay worked for me. Tiled a bathroom floor and a shower.
Old 12-03-2011, 12:44 PM   #5
Electrical Contractor
kbsparky's Avatar
You can get jig saw blades for cutting tile by going here.
Also available at Sears.
-KB
Old 12-03-2011, 01:09 PM   #6
Rewards Points: 12,830
Roto Zip also has a tile cutting bit.
Old 12-03-2011, 01:13 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
You can buy a small tile saw for $35
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-04-2011, 12:20 PM   #8
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Any way you look at it is scroll saw is just a bad idea. Those things jerk the wood around too much for me since they move up and down. I can only imagine what that would do to tile. I'm hesitant on a jigsaw as well since you are trying intricate cuts. Grinder or rotozip/dremel bits would be my choice if a tile saw is completely out of the question. My $80 7" saw has been going strong for years though. Well worth the investment.
Darkling Designs
poppameth is offline   Reply With Quote
Old 12-04-2011, 12:53 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What do you consider "intricate cuts"? What exactly are you doing?
XXX
Old 12-05-2011, 12:35 AM   #10
Different size radius mostly. I have a rotozip so I think a bit for that will be the trick.
Old 12-05-2011, 12:36 AM   #11
What type of wet saw do you have?
Old 12-05-2011, 03:53 AM   #12
Stuck in the 70's
I just looked at the box. It says "Qep", but it is a basic cheap 7" wet saw you can find under many different brand names.
Old 12-05-2011, 06:49 AM   #13
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The QEP is that same one I've got. The only drawback to it is constantly adding water to the reservoir since it has no pump.
Darkling Designs
Old 12-05-2011, 11:34 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't expect the Dremel or its tile bits to work.
XXX
Old 12-06-2011, 09:56 AM   #15
robertBny's Avatar
Why not just get a budget wet saw from a big box store. They're like $70 including a blade. They're not the greatest saws in the world but they'll make a 100x better cut than a scroll saw or saw zall. I use mine for installing backsplashes. They shoot out more water than a pro wet saw but they cut nice.
robertBny is offline   Reply With Quote
Tags
ceramic tile , tile cutter
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 11:09 AM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 09:11 PM
