-   -   Cutting ceramic tile with a scroll saw? (http://www.diychatroom.com/f5/cutting-ceramic-tile-scroll-saw-125449/)
HandyHunter 12-03-2011 12:29 PM
Hi,
I've started a small tiling project for an entryway and have a few intricate cuts to make. I don't want to shell out for a tile saw and I have 2 more small projects down the road so I would prefer not to have to rent a saw 3 times.
Is there a scroll saw blade made for cutting ceramic tile? If so, what kind and where would I find this?
Thanks!
titanoman 12-03-2011 12:37 PM
Originally Posted by HandyHunter (Post 784889)
Hi,
Thanks!
I've never seen tile cut with a scroll saw. It would require a masonry blade, which I don't think they make for a jigsaw, though I could be wrong.
ccarlisle 12-03-2011 12:39 PM
What's wrong with a 3" carbide blade on your 4" grinder...?
Blondesense 12-03-2011 12:43 PM
You can pick up one of those small, cheap wet saws for about what it would cost to rent a big one for one day.
That and a diamond drill bit off of ebay worked for me. Tiled a bathroom floor and a shower.
kbsparky 12-03-2011 12:44 PM
You can get jig saw blades for cutting tile by going here.
Also available at Sears.
http://www.hudsonmayor.com/images/31HDRW82CGL.jpg
joecaption 12-03-2011 01:09 PM
Roto Zip also has a tile cutting bit.
rusty baker 12-03-2011 01:13 PM
You can buy a small tile saw for $35
poppameth 12-04-2011 12:20 PM
Any way you look at it is scroll saw is just a bad idea. Those things jerk the wood around too much for me since they move up and down. I can only imagine what that would do to tile. I'm hesitant on a jigsaw as well since you are trying intricate cuts. Grinder or rotozip/dremel bits would be my choice if a tile saw is completely out of the question. My $80 7" saw has been going strong for years though. Well worth the investment.
Bud Cline 12-04-2011 12:53 PM
What do you consider "intricate cuts"? What exactly are you doing?
HandyHunter 12-05-2011 12:35 AM
Different size radius mostly. I have a rotozip so I think a bit for that will be the trick.
HandyHunter 12-05-2011 12:36 AM
What type of wet saw do you have?
Blondesense 12-05-2011 03:53 AM
I just looked at the box. It says "Qep", but it is a basic cheap 7" wet saw you can find under many different brand names.
poppameth 12-05-2011 06:49 AM
The QEP is that same one I've got. The only drawback to it is constantly adding water to the reservoir since it has no pump.
Bud Cline 12-05-2011 11:34 AM
Don't expect the Dremel or its tile bits to work.
robertBny 12-06-2011 09:56 AM
Why not just get a budget wet saw from a big box store. They're like $70 including a blade. They're not the greatest saws in the world but they'll make a 100x better cut than a scroll saw or saw zall. I use mine for installing backsplashes. They shoot out more water than a pro wet saw but they cut nice.
