Cutting Cementboard With 4.5" Grinder Diamond Blade - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 05:38 PM   #1
Rewards Points: 1,062
Question
cutting cementboard with 4.5" grinder diamond blade
i have discovered that by far the most efficient way of cutting cementboard is with a grinder and a diamond blade. this is far better than d...ing around with scoring it with a utility knife and having to do it until the cows come home and then trying to break along the score. sorry, i just don't have the patience for that. i want it cut and that's that...
however, the question is that of safety and dust inhalation. when doing that, i do wear a gas mask type respirator. there still is dust EVERYWHERE so i do it outside. how protective is the respirator in this case? and how harmful is the dust that sets on the ground if it doesn't get vacuumed right away?
thanks
Old 02-21-2012, 08:17 PM   #2
DIY staff
Rewards Points: 7,174
That's a messy job----but done frequently by pros for the goofy cuts--One good score with a knife works for me--
I have a 4" diamond bladed circular saw---with that ,you slap a sponge full of water against the blade and the dust is not a problem---
Rock dust isn't good for the lungs or your hair--the grass won't mind---If you are doing a lot of this type of work---buy a wet cutting circular saw---Harbor Freight has a nice one for cheap--Mike---
Old 02-21-2012, 08:21 PM   #3
Rewards Points: 13,282
I found a ciruler saw with a 5" blade on it with a water line built right in that blows on the blade.
I got it at Lowes in the tile area.
Old 02-21-2012, 08:30 PM   #4
Question
sure but do you need water just to alleviate the harmfulness or does it make difference in cut quality? because my cut with a $10 Huskey diamond blade was no short of spectacular.
Old 02-21-2012, 08:37 PM   #5
DIY staff
Doesn't make the cut better---but the dust will really irritate a customer--so most of us use water
The circular saws spin slower than a grinder so using a soaking wet sponge works just fine--
For one job? Make dust--cough twice and sweep up!
amakarevic (02-21-2012)
Angle grinder blade for cutting through tile? darsunt Tools 3 02-23-2012 05:37 AM
Best Tools for Drywall Removal? neo95gt Drywall & Plaster 59 12-27-2011 01:44 PM
Circular blade for cutting hardwood? WillK Building & Construction 4 02-09-2011 01:14 AM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
life span of masonry diamond segmented blade 4just1don General DIY Discussions 5 06-22-2010 02:37 PM
