-   -   cutting cementboard with 4.5" grinder diamond blade (http://www.diychatroom.com/f5/cutting-cementboard-4-5-grinder-diamond-blade-134531/)
amakarevic 02-21-2012 05:38 PM
i have discovered that by far the most efficient way of cutting cementboard is with a grinder and a diamond blade. this is far better than d...ing around with scoring it with a utility knife and having to do it until the cows come home and then trying to break along the score. sorry, i just don't have the patience for that. i want it cut and that's that...
however, the question is that of safety and dust inhalation. when doing that, i do wear a gas mask type respirator. there still is dust EVERYWHERE so i do it outside. how protective is the respirator in this case? and how harmful is the dust that sets on the ground if it doesn't get vacuumed right away?
thanks
oh'mike 02-21-2012 08:17 PM
That's a messy job----but done frequently by pros for the goofy cuts--One good score with a knife works for me--
I have a 4" diamond bladed circular saw---with that ,you slap a sponge full of water against the blade and the dust is not a problem---
Rock dust isn't good for the lungs or your hair--the grass won't mind---If you are doing a lot of this type of work---buy a wet cutting circular saw---Harbor Freight has a nice one for cheap--Mike---
joecaption 02-21-2012 08:21 PM
I found a ciruler saw with a 5" blade on it with a water line built right in that blows on the blade.
I got it at Lowes in the tile area.
amakarevic 02-21-2012 08:30 PM
sure but do you need water just to alleviate the harmfulness or does it make difference in cut quality? because my cut with a $10 Huskey diamond blade was no short of spectacular.
oh'mike 02-21-2012 08:37 PM
Doesn't make the cut better---but the dust will really irritate a customer--so most of us use water
The circular saws spin slower than a grinder so using a soaking wet sponge works just fine--
For one job? Make dust--cough twice and sweep up!
