11-09-2012, 08:43 AM
#1
cutting cement board
I'm replacing linoleum in our bathroom with tile, and am planning to install 1/4 cement board underneath. Our bathroom is really small and has small sections/walls that protrude, and I was wondering if anyone has any tips for cutting notches into cement board. Everything I can find on cement board seems to assume that every room is built for perfectly straight cuts!
Thanks!
11-09-2012, 08:51 AM
#3
Unfortunately I don't think that will work in my case, as some of the parts that are protruding are only 4 to 5 inches across and a couple inches deep.
11-09-2012, 09:01 AM
#4
11-09-2012, 05:58 PM
#5
Tileguy
I have this strange feeling that Cjohn is not interested in buying a CBU shears ($200-300) to do his tiny bath floor. Just a feeling though.
You can make small "U" cuts into concrete board with even just a razor knife and a few other regular tools, but it can take some time. Alternatively you can cut the larger sheet into smaller pieces so you'd be making "L" instead of "U" cuts. A carborundum blade on a sabre saw is available too.
The easiest and cheap way is to use a side grinder like this. http://www.google.com/imgres?q=side+...9,r:0,s:0,i:88
Some are available for under $40 and Harbor Freight should have one for under $20. It's a tool you'l use many time including to score the concrete board & certain tile cuts maybe.
It does produce dust so use it outside with a fan behind you blowing the dust away. A mask is smart.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
11-10-2012, 12:12 PM
#6
Sawz-all with a metal blade, no dust no fuss
11-12-2012, 09:37 AM
#7
You nailed it Jazman--lot looking to spend that much on a $200 bathroom tile job  . Thanks for the tips, it looks like that grinder is probably the best option. Thank you all for your advice!
11-12-2012, 09:54 AM
#8
Don't WANNA do it myself
I used my RotoZip with a cement blade on it. Very easy to use and really precise because it's small and light.
Michelle
Fixing the re-muddling one room at a time...
11-12-2012, 06:39 PM
#9
Drill about a million holes it and connect the dots with a chisel . Tinme consuming , But the least of buying a bunch of tools , Also a scribe will work , Just scribe it about 20 times till you work a weak spot , Drill the corners tacomahardwoodfloors.com
11-13-2012, 12:32 AM
#10
I just finished a huge siding/trim project with 1/4 hardi plank. we used a simple diamond cement 7.5" circular blade for our miter and table saw. Works just fine.
11-13-2012, 08:18 AM
#11
TacomaHardwood--Did you use a special drill bit?
11-13-2012, 09:17 PM
#12
Tileguy
Yes, he probably uses one that will last long enough to make a million holes.
You're not actually thinking of doing that are you?
Jaz
11-14-2012, 08:10 AM
#13
I have to cut out a hole for the toilet flange as well, and I was thinking some drill holes would work best for that, unless there's a better option?
11-14-2012, 09:38 PM
#14
Tileguy
I already gave you the answer in post #5 above. Use a grinder if you have one. Of course drilling a bunch of holes will work too.
In the old days when Wonderboard first came out we didn't use or know of all these many tools available today. We made a hole by first scoring the surface and embedded mesh with a regular utility knife or laminate scriber, and then tap with a hammer to complete the hole. So, I recommend the grinder with a fan blowing or a jig saw with appropriate blade.
Jaz
11-14-2012, 09:52 PM
#15
Average Joe/ex-Navy IC3
Instead of Cement Board, the better option is Georgia-Pacific's DensGuard http://gp.com/build/product.aspx?pid=6388 or DensShield http://gp.com/build/densshield-tilebacker-board I used DensShield for our bath floor, and it is easy to work with, and holds up as good as Cement Board.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
