Old 11-03-2009, 06:43 PM   #16
long island, NY
Originally Posted by R&D Tile View Post
diy'er on LI, what is it you want to install, stone or the porcelain tile?
What size joists, spacing and unsupported span of them do you have where this tile or stone is going?
this is in the future (sometime next year?).... so we haven't given it much thought yet. Ideally, if there were no limitations, we would install 24" granite, but porcelain is also a possibility. I merely chimed in becuase I am clueless as to the limitations of tile floors on a 2nd floor of a wood home.
what are generally the requirements for joists, spacing, and subflooring for larger tile floors? is it rather difficult and complicated? If it is, I'll bypass aesthetics and go with good ol' 12" tiles or even smaller. It's simply not worth jumping through hoops to us...
thanks
diy'er on LI is offline   Reply With Quote
Old 11-04-2009, 08:43 AM   #17
ccarlisle's Avatar
Well, what you need to do a granite floor depends on what you already have - but I can almost say with 100% certainty that you'll need to strip the floor back down to the joists and rebuild it. That's only because most houses aren't structurally built to take the weight of granite tiles.
The result of NOT doing this is cracked grout or worse cracked tiles due to bouncing floors.
ccarlisle is offline   Reply With Quote
Old 11-04-2009, 01:58 PM   #18
long island, NY
yikes.... scrap the granite idea then. so porcelain is lighter and requires less subflooring work?
right now we're so winded from working and taking care of a baby while redoing our downstairs 1/2 bath that peel-and-stick vinyl is starting to look better and better to me
Old 11-04-2009, 03:43 PM   #19
ccarlisle's Avatar
OK, this has gone way farther than the original poster wanted it to go but it has opened up a ton of questions and answers...someone asked me what I meant by "L/720"...these ratios are deflection limits or measures of stiffness.
"L/360" is typically the maximum allowable deflection for a floor under maximum design load allowed by building code, where "L" is the span length in inches. For example, to meet L/360, a 10 ft floor joist can bend a maximum of 1/3" under its max design load (10' x 12" = 120" / 360 = 1/3"). So, to meet "L/720", that same joist can only bend 1/6" (120"/720=1/6").
Basically a floor designed to "L/720" is twice as stiff as a floor designed to L/360. And to meet one or the other depends on what you already have and may or may not require stiffer joists and/or another layer of plywood to meet the maximum alllowable deflection. There's more to it but that's it in a nutshell...
Old 11-04-2009, 08:40 PM   #20
Adding plywood doesn't strengthen the floor as far as the joist system, it only adds strength to the flex between the joists.
Two layers of wood are better than one, then a CBU or membrane of choice.
You NEED two layers of wood if stone is used, one layer of 3/4" ply for ceramic, which is bare minimum.
Best to come back when you decide what you want to install.
R&D Tile is offline   Reply With Quote
Old 11-05-2009, 03:00 PM   #21
long island, NY
thanks so much for the info. I'm definitely keeping this in mind for the future. (Sorry to the original poster for unintentionally hijacking the thead! )
Tags
35", bathroom, porcelain tiles, rip cut, tile cutter
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Trees are beautiful and useful elements to any landscaping design. Removing a tree to make room for your deck project is not only unnecessary, but may cause more trouble for your yard in the future. Instead of removing the tree, include these majestic... Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 05:34 PM
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 03:57 PM
Ceiling Tiles - Cutting accoustic tiles tstepup2 General Discussion 11 07-21-2009 08:19 PM
Cutting Porcelain Tiles unsure diyer Tiling, ceramics, marble 1 07-03-2009 11:20 PM
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
