cutting 18" tile
You're right I meant to say tile, I had travertine on my mind from another thread. Actually travertine is softer than most tiles. Either way you wouldn't want to have to cut very many with a saw like that. Some cuts, you couldn't even do at all.
Depending on how many, might be a good idea to have them cut unless you're a seasoned DIY'er. Heck, if all the cuts get covered with moldings, you could use a side grinder. If straight cuts rent or borrow a cutter and have the L and U cuts done on a larger saw.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
