-   -   cutting 18" tile (http://www.diychatroom.com/f5/cutting-18-tile-12537/)
bobloj 10-19-2007 07:32 PM
cutting 18" tile
Any ideas to cut 18" tile...the rentals at home depot only cut up to 12" tile??
NateHanson 10-19-2007 09:23 PM
Check a dedicated equipment rental place. HD rentals are pretty limited in my experience.
the roofing god 10-19-2007 10:00 PM
buy a table w/a 7"blade,only about 90$ well worth the money !
JazMan 10-19-2007 10:50 PM
A ninety dollar saw to cut 18" stone? Heck, the proper blade alone might cost more than that?
Jaz
the roofing god 10-19-2007 10:53 PM
nobody said stone,works fine w/ceramic
JazMan 10-19-2007 11:26 PM
You're right I meant to say tile, I had travertine on my mind from another thread. Actually travertine is softer than most tiles. Either way you wouldn't want to have to cut very many with a saw like that. Some cuts, you couldn't even do at all.
Depending on how many, might be a good idea to have them cut unless you're a seasoned DIY'er. Heck, if all the cuts get covered with moldings, you could use a side grinder. If straight cuts rent or borrow a cutter and have the L and U cuts done on a larger saw.
Jaz
the roofing god 10-20-2007 10:03 AM
i`M NOT A PRO AT THIS BUT Iwas told that the grinder heated the tile too much and caused stress cracks ?????just done my own bathrooms etc.
