-   -   Cutback Removed -- Now What?? (http://www.diychatroom.com/f5/cutback-removed-now-what-130042/)
Murdy 01-15-2012 10:08 AM
I received some (apparently) bad advice and spent a lot of hard time and messy effort removing a thin layer of cutback using paint thinner from a concrete slab. Should have researched this better first. It left what looks like a stain on the slab, now I hear that chemical residue may be a problem.
Should have researched this better first. Anyone have an opinion on how to proceed? Soap and water? Drysweep? Just lay right over it (we are using a modified thinset)? Any other good ideas?
I'd appreciate any advise.
Murdy 01-15-2012 10:15 AM
Sorry, tried to edit and somehow this posted twice. If moderator wishes to remove redundant one, please feel free.
oh'mike 01-15-2012 10:27 AM
How long ago did you use the thinner?
I suggest you use a two part thin set for this---that is the best bet as you have a possible bond breaker going there--
Unmodified mixed with liquid latex or acrylic---Kerabond and Keralastic is a good example--
"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Murdy 01-15-2012 10:46 AM
2 days.
I have ultraflex 2 (MAPEI) on site (supposedly, this is professional grade as opposed to ultraflex 1). When you say "use a two part thin set for this," do you mean making my own modified by buying unmodified and adding an additive and then proceeding normally, or are you suggesting a 2 step application? Or increasing the ratio of additive to 2 parts? (sorry if this is a dumb question, I assume its the first option, but want to make sure, thanks).
oh'mike 01-16-2012 04:44 AM
Ultra flex is a good modified--But I always used unmodified and a liquid--that has never failed me--
I think you have waited long enough--
Murdy 01-16-2012 06:52 AM
Thanks for the advice. We won't be getting back to the project until next weekend, so it'll have some more time to sit.
Thanks again.
