Cutback On Our Basement Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 12:44 PM   #1
Cutback on our basement floor?
Our house was built in 1923 and when we purchased it a year ago, it came with a finished basement. That basement turned out to be our worst nightmare because we had no idea what was behind the walls, under the ceilings, or under the carpets.
To make a long story short, the winter and spring brought major water problems to our basement and caused the carpets to smell. We decided to rip a small section of the carpet out and discovered what appears to be dryrot linoleum (which cracks and lifts with the carpet) and a black tar substance underneath. From researching so far, it sounds like the black tar could be "Cutback" since the basement was remodeled in the 60's or 70's.
We are looking for the easiest way to deal with the black tar to make our basement useable. It doesn't have to be pretty - we just have to be able to walk down there without sticking to the floor.
Can we paint the "Cutback?" Could we use a product like Ardex Feather Finish and then paint that or leave it bare?
Any suggestions are appreciated...
Cutback on our basement floor?-photo.jpg   Cutback on our basement floor?-photo-2-.jpg
niclic is offline   Reply With Quote
Old 09-05-2011, 02:22 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can scrape away the ridges in the cutback using a 3 or 4 inch razor-blade type scraper then you can skim over it with one of the Ardex products made for the purpose. If you don't scrape everything down to where only a stain is remaining the Ardex can crumble when walked on.
XXX
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 02:35 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 12:49 PM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 10:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Basement floor reno D.RED Flooring 1 06-21-2006 02:20 PM
