Cutback Asphalt Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 01:40 AM   #1
cutback asphalt adhesive
I removed carpet from interior room and found cutback over the cement slab, slab is 40yrs old.
I like to paint over the cutback adhesive instead of disrturbing it.
What primer and paint can I use?
California has restrictions on oilbased primers and paints.
Can I just apply paint that is used for regular cement floors?
maghan is offline   Reply With Quote
Old 07-22-2013, 10:01 AM   #2
Rewards Points: 93
I would test it for asbestos. You have to get a lab to do this and cost us in DC Metro area $220. If you dont want to do that I hear you can encapsulate it with something called TriSeal http://www.xlbrands.com/category/products/floor-prep/ it does have moisture limitations.
Also if you want to encapsulate it a product called Ardex Feather Finish does that also.
7 VII 7 is offline   Reply With Quote
Tags
cement paint , cementfloor , cutback adhesive
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 02:48 PM
What is 'cold set asphalt adhesive'? darsunt Roofing/Siding 5 10-14-2010 12:49 AM
tiling over cutback adhesive residue kailuacathy Flooring 2 09-09-2010 09:03 PM
Options for resurfacing over old cutback adhesive burlis Flooring 1 06-11-2008 04:35 AM
sealing cutback adhesive Mikon Flooring 3 10-17-2007 11:08 AM
