Cut Nails - Flooring - DIY Chatroom Home Improvement Forum
Old 04-22-2008, 12:22 PM   #1
Rewards Points: 274
cut nails
I am having new pre-finished wide plank 3/4" pine hardwood installed and have decided to face nail (in addition to hidden nails) instead of spending $400-$500 on adhesive. Any opinions on face nailing with cut nails and pre-driiling pilot holes ie: boards splitting, versus using regular finish nails with nail gun? Thanks...
ugabulldog is offline   Reply With Quote
Old 04-22-2008, 10:01 PM   #2
Rewards Points: 274
follow-up question: I am going w/ cut nails and pre-drilling pilot holes, should I use 8d= 2 1/2" or 6d= 2" nails..... 3/4" hardwood, 3/4" advantec, nailing into floor joists, thanks.
Old 04-23-2008, 12:19 PM   #3
Hi
Didn't the manufactures of your flooring have nailing scheduling and size,beings that your going with wide plank?I bought some plank from a mil,1" thick,9" to 13" wide and nothing less than 7`long. He (The Rep)had all that sort of information for me.He even gave me a plastic nail pattern for drilling and nailing.Seems odd your in this dilemma.I used 2.5 cut nails, 4 nails on the ends and 3 every 2` in the field.Hope this helps you out. Call your rep...............................
mark942 is offline   Reply With Quote
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 10:25 AM
Protruding nails through exterior patio roof miami789 Roofing/Siding 7 06-25-2007 03:42 PM
Rusting nails on exterior firsthomegal Painting 7 05-28-2007 06:15 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
Deck nails jimgibson Carpentry 12 10-09-2005 03:22 PM
