Curved Tile To Carpet Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 03:04 PM   #1
toocheaptohire's Avatar
Curved tile to carpet transition
I'd like to install tile in a room that will be mostly carpeted. The tiled portion would be in front of french doors and along a wall just next to and perpendicular to the doors along which a coat rack and bench will be positioned (mud room corner, if you will). I'd prefer the shape of the tiled area to be more curved than hard 90 degree angles - attached a rough sketch of what I'm trying (poorly) to describe. My question is - do I need to find a "curveable" edger to between the tile and carpet (and would that be installed before tile?) or can I put tile in and have carpet installed butted up against the curving tile border? Carpet would be installed by pros, tile by moi.
toocheaptohire is offline   Reply With Quote
Old 04-08-2009, 08:13 PM   #2
If you're on concrete, professional carpet installers should have no problem tucking the carpet directly to the tile.
In my own opinion, tucking the carpet to the tile looks best.
Mudd is offline   Reply With Quote
Old 04-09-2009, 05:41 AM   #3
Remodeling Contractor
Use small pieces of tack strips to make the curve and tuck the carpet.
Old 04-09-2009, 09:03 AM   #4
Great - just the feedback I needed - thanks!
Old 04-09-2009, 12:53 PM   #5
Floorwizard's Avatar
Agreed. If you don't like the look afterwards...consider trac n cap
Floorwizard is offline   Reply With Quote
Old 04-16-2009, 03:37 PM   #6
I agree with Bob, I have been istalling carpet for 21 years and the carpet is always tucked in against the tile edge with tackless in front of the tiles. cheers Dan
dan wylde is offline   Reply With Quote
Redo transition from carpet to tile bkeech Flooring 1 11-08-2008 08:02 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
carpet to tile transition jeeper36 Flooring 1 10-26-2007 11:16 PM
