Curved Saddle - Flooring - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 09:09 PM   #1
curved saddle
one big room they half laminate the other stick on tile, the problem is there is a S shape design they want between the floor and the tile, how can I separate the rooms
merlot is offline   Reply With Quote
Old 05-15-2012, 09:19 PM   #2
Rewards Points: 12,802
That post makes little since.
#1 There two differant thickness.
#2 Peel and stuck is the lowest of the low as far as flooring goes.
#3 Laminite flooring has to float and would need a transition strip between it and any other flooring, how would you do that with a curve.
Old 05-15-2012, 09:26 PM   #3
DIY staff
Rewards Points: 7,174
Call the flooring manufacturer and see if they have a flexible transition---there are nice ones for carpet--but if they insist on Laminate and peal and stick tile--a fancy transition that will allow the floor to move is not likely in the budget.
With a band saw and a router table--it could be fabricated--but that is going to take time--and money--seldom spent by folks who buy laminate and vinyl tile.
Old 05-15-2012, 10:33 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Probably cost more for the custom transition than their laminate and tile combined.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (05-16-2012)
curved wall and curved floor joins pstur1 Building & Construction 2 12-05-2010 01:01 PM
Installing laminate in a room with one big curved wall (PICS) vu321 Flooring 9 06-04-2010 04:15 PM
can I runa second line from a pre-existing saddle valve? ClancyKev Plumbing 1 10-23-2009 07:02 PM
Saddle for screen porch gorf Roofing/Siding 1 06-19-2009 05:33 PM
