Crucial Error - Flooring - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 09:14 AM   #1
crucial error
i'm glad this forum is more or less anonymous.
My tile floor turn out pretty well. Installed radiant heat underneath..yea! We are at the end of the project and i go to install the thermostat; with all of the other crap that was happening at the same the tile was being set... we managed to NOT install the thermostat wire with the rest of the wiring. OOPS. So now a guy needs (me) needs to fish the thermo wire down the wall and into the floor. Here is the question. What is the best/safest method for removing this one 12x12 ceramic tile that is set on concrete with radiant wire underneath? I'm thinking that scaping the grout and trying to pry the tile up in pieces? My wife says "it will be OK." I feel this screw-up is wrought with disaster. help. The good news is this tile is atleast in a very conspicous spot.
hayduke.klr07 is offline   Reply With Quote
Old 01-11-2009, 09:51 AM   #2
First off, if your wife says its okay, Your Golden! but yes it would seem that you could break up that tile and go from there. I'd try a chisel and hammer, knowing wire is under neath, go easy. As for how it happened, someone on here has in his signature about if we haven't made a mistake we aren't living, good luck and congrats on your new floor.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-11-2009, 11:52 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
hayduke,
YOU ARE ASKING FOR TROUBLE.
How about you gently remove the grout in a grout line and install the probe in that channel then regrout.?
The probe doesn't have to be under a tile, it only needs to be somewhere in the thermal mass.
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 07:45 PM
