Crowned Joist / Uneven Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 12:09 AM   #1
Crowned joist / uneven floor
I have the same problem. Home is 15 years old. Uneven floor came up in 3-4 months. Elevated several inches above floor level. Any ideas or cures? Recently found another bump between the utility room and kitchen. No water leaks on press board as far as I know.
unionjack is offline   Reply With Quote
Old 08-26-2010, 07:58 PM   #2
floor_whore
Send a message via Yahoo to Aaroncarpet
fixing a high joist
Cut the plywood away from the high joist and buy a new sharp 2" chisel and chisel the top of the joist and then replace the plywood.. the levelers will crack and shrink....cut the sub flooor and chisel the joist... the top of the joist can be chiseled without sistering and crazy stuff....you will need to remove some plywood
Aaroncarpet is offline   Reply With Quote
Old 08-26-2010, 09:17 PM   #3
crowned joist/ uneven floor
Thanks for the info. What causes this problem? Is it settling or faulty materials or construction?
Old 08-27-2010, 09:25 AM   #4
floor_whore
why does this happen
if it is a newer home it is because they built too soon after grading the soil and didn't let the soil settle enough. and maybe not the best construction method..if it is an older home just gravity rules.....
The Following User Says Thank You to Aaroncarpet For This Useful Post:
unionjack (08-27-2010)
Old 08-28-2010, 11:15 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WOW! I'm not convinced THAT procedure would be the lessor of the evils. I'm thinking THAT APPROACH would be the "crazy stuff". Oh well...I learn something new everyday.
XXX
Old 08-28-2010, 11:20 AM   #6
floor_whore
You may be right bud....it works if you don't have access to the joist from below...
Old 08-28-2010, 11:29 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good point, hadn't thought of that. I can see/imagine a few drawbacks tho.
XXX
Old 08-28-2010, 11:35 AM   #8
floor_whore
Yeah you need a straight edge to determine how much to chisel off.. and if you don't know how to use a chisel it could take a while..., but if you are going at least 1/4" and remove enough subfloor you could probably do most with a sawzal and clean the ends with a chisel...
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Screwing down subfloor & crowned joist? roar24 Flooring 1 03-20-2011 04:27 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Cracked Floor Joist - what to do? Knucklez Building & Construction 25 08-10-2010 01:21 PM
crowned joist / uneven floor shawn99 Flooring 22 01-13-2010 02:11 PM
