Crowned Hardwood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 08:18 AM   #1
We installed radiant heat on the subfloor, between 2x4 nailers and poured a gypcrete like material over it as a heat transfer. We did not let the gypcrete-like material completely cure and the floors started to cup, then they reversed and crowned, which is where we are now.
We also put this same flooring down in a closet, after things were dried/cured and we have no problem. We rushed the other flooring and want to know if ANYONE has any ideas if and how to correct our washboard floors. They are 8", 10" and 12" widths, heart pine.
We thought maybe some direct heat to the top of the boards, to force them to dry more and they may go back down, but heating a 16' board at the same time looks like the issue.
Thanks for whatever you might be able to offer - Bishop
bishop is offline   Reply With Quote
Old 05-12-2010, 08:26 AM   #2
cupping is caused by moisture evaporating faster out one side than the other. you may have to take floors up, stack on hard surface and apply weight, they may with time flatten. have you talked to the people you got flooring from
The older I get the better I was
Old 05-12-2010, 08:33 AM   #3
Crowned Floors
Thanks for the suggestion, and that is what we may have to do, but the idea of applying heat to the crowned side, was to hope to draw out the moisture, having the boards return to flat. The floor company has been very supportive, but they have no suggestion, other than the usual ones...
Tags
cupped floors , radiant heat floors
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
Hardwood Flooring transition msfmatt Flooring 2 05-21-2009 07:57 AM
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 09:22 PM
Hardwood flooring on stairs / split level Badger_DIYer Flooring 4 03-20-2009 05:00 PM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 07:54 AM
