Creaking Floorboard - Flooring - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 07:59 PM   #1
Creaking Floorboard
What is usually recommended for creaky floorboards? I am starting to
notice it throughout the house these days. I don't think it was always like
that. What is the cause and how do I go about silencing the squeak?
Thanks.
BlaJoRon is offline   Reply With Quote
Old 11-05-2011, 08:14 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The place is haunted - call Ghost Busters.
Actually do a search here. This just came up here in the past few days and some guy had a gizmo made fixing squeaky floors.
I'll see if I can find it.
Old 11-05-2011, 08:17 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Here ya go....
Click on the link in the first post:
squeaky floors!
Still do a search tho, it gets discussed here every once in a while.
Old 11-06-2011, 10:59 PM   #4
you may come across a board which has been cut between two joists with the result that nothing is supporting the join. You will then have something to fix the loose end to with screws.
Kaylee is offline   Reply With Quote
Old 11-07-2011, 01:21 AM   #5
Thanks.
A easy way to fix the noise without doing alot of work.. Look for the gap in the join at the joists.. Use chalk from a chalk line marker and work chalk into gaps.. It acts like lube between the gaps and stops the noise... It's easy and fast.. Lasts a while also.
Sent from my iPhone using DIY Forum
Mack daddy is offline   Reply With Quote
Whirlpool Creaking Ice Maker ambar Appliances 1 06-12-2009 11:01 AM
after flush toilet creaking sounds down the piping for about 20 seconds depstein Plumbing 1 05-11-2009 06:39 AM
How to Stop the Wooden Floor from Creaking? loomb8 General DIY Discussions 2 11-20-2008 10:37 AM
creaking wall board or possible hvac problem altoon HVAC 2 01-03-2008 02:40 PM
Carpeted floor creaking - suggestions/experience? WolfStock Flooring 12 06-30-2007 05:19 PM
