-   -   Creaking Floorboard (http://www.diychatroom.com/f5/creaking-floorboard-122490/)
BlaJoRon 11-05-2011 07:59 PM
Creaking Floorboard
What is usually recommended for creaky floorboards? I am starting to
notice it throughout the house these days. I don't think it was always like
that. What is the cause and how do I go about silencing the squeak?
Thanks.
Bud Cline 11-05-2011 08:14 PM
The place is haunted - call Ghost Busters.:)
Actually do a search here. This just came up here in the past few days and some guy had a gizmo made fixing squeaky floors.
I'll see if I can find it.
Bud Cline 11-05-2011 08:17 PM
Here ya go....
Click on the link in the first post:
http://www.diychatroom.com/f15/squeaky-floors-122295/
Still do a search tho, it gets discussed here every once in a while.:)
Kaylee 11-06-2011 10:59 PM
you may come across a board which has been cut between two joists with the result that nothing is supporting the join. You will then have something to fix the loose end to with screws.
Mack daddy 11-07-2011 01:21 AM
Thanks.
A easy way to fix the noise without doing alot of work.. Look for the gap in the join at the joists.. Use chalk from a chalk line marker and work chalk into gaps.. It acts like lube between the gaps and stops the noise... It's easy and fast.. Lasts a while also.
Sent from my iPhone using DIY Forum
