Crazy?....but How Do I Install Hardwood Flooring On Wall - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 10:02 PM   #31
yummy mummy's Avatar
Rewards Points: 1,016
Thanks moomdawg.
That is a good idea, but I don't have a circular saw for that. I guess I would have to use my handsaw.
I saw wood veneer that looked interesting the other day. I guess I would put that on with glue?
Then I would have to stain it.
yummy mummy is offline   Reply With Quote
Old 01-07-2009, 07:33 AM   #32
Rewards Points: 156
Originally Posted by yummy mummy View Post
Thanks moomdawg.
Most big-box stores will cut the plywood for you on a panel saw if you give them the dimensions. You could also look on craigslist for a used circular saw. there's cheap tools aplenty over there.
moondawg is offline   Reply With Quote
Old 01-07-2009, 09:50 AM   #33
Tom Struble's Avatar
Rewards Points: 2,002
why flooring and not t&g pine or cedar siding?they usually have 1 side beveled and 1 side square
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 12:45 PM   #34
Ok, here goes the dumb question.......
What is tongue and groove pine and cedar siding? Where can I go and take a look? Home Depot?
Also, I don't want the bevelled edge showing. What I would like to get is no groove inbetween, like a whole sheet what there, if possible.
Old 01-08-2009, 02:35 PM   #35
Uh, not to open a can of worms here but I just stripped oak flooring off my neighbours wall. Have you considerred all the perforations you might be making in your vapor barrier if this is an insulated wall and will that be an issue in your location?
Chemist1961 is offline   Reply With Quote
Old 01-08-2009, 02:51 PM   #36
Sorry I didn't read way back 3 pages but has anyone suggested premium 1/4" plywood with the surface wood of your choice. I had an oak feature wall done this way 20 years ago. It was stunning and applied mainly with adhesive panel caulking. You could cut it to your preferred height and cap it with chair rail or similar. In fact a specialty plywood store would likely cut it for you, first cut free.
Old 01-08-2009, 05:52 PM   #37
One of the walls has insulation and vapour barrier, but I will only be nailing into the studs.
Old 01-08-2009, 06:19 PM   #38
Sorry I thought you were considering laying the flooring vertically up your walls.
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
