Cracks On Slab, Problem For Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 05:39 PM   #1
Rewards Points: 337
cracks on slab, problem for tile?
I pulled the carpet up and found some cracks in the slab. They run almost 18 feet across the room. We wanted to put 20" tile down with one of those anti movement pads. Will we be okay with these cracks or is wood flooring a better option. I only in a small area is the crack perhaps 1/32" higher on one side, if even that much.
titan7 is offline   Reply With Quote
New Basement with Moisture Problems from Slab fasteddie Flooring 41 01-14-2010 02:01 AM
Help! Tile-over-concrete slab problems jeffchri Tiling, ceramics, marble 6 12-24-2008 05:22 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Can I set a cabin on top of mobile home slab? birchbarx Building & Construction 4 03-22-2008 06:06 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
