Cracked Tile In Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 03:23 PM   #1
cracked tile in kitchen
I have about 6 cracked tiles in entrance to kitchen, do not have any extras and unable to find same tile. Should I lay laminate over the whole kitchen floor (about 200sq ft) ? any other options. Thanks
reets is offline   Reply With Quote
Old 12-09-2011, 04:52 PM   #2
Rewards Points: 272
it depends on what kind of tile you have there right now. You might also want to look at the option of removing those tiles and maybe one or two more and replace with another tile to make some kind of pattern out of it. To me that would be the easiest solution, that is if the uncracked tiles are easy on the eyes.
fixrite is offline   Reply With Quote
Old 12-09-2011, 04:56 PM   #3
cracked tile
thanks, we told that also, problem is dont know if this tile was set just on concrete as looks like it is cracking in more places, is 10yrs old.
Old 12-09-2011, 04:59 PM   #4
Rewards Points: 272
sounds like you need to remove some tiles to see just what you have so you can make the right decision to fix one way or another.
The Following User Says Thank You to fixrite For This Useful Post:
reets (12-09-2011)
Old 12-09-2011, 05:13 PM   #5
Thanks, yes I think I will do that.
Water under tile in kitchen jchannon Flooring 5 08-17-2013 11:00 AM
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 12:40 PM
Small Crack on Tile in kitchen area tk3000 Flooring 3 09-05-2011 04:24 AM
Kitchen tile job planning.. ? .. stoneda7086 Flooring 13 03-05-2011 06:43 PM
kitchen floor tile popping up clashley Flooring 3 01-17-2011 06:39 AM
