Covering / Sealing Old 1950's Vinyl Flooring - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 12:49 PM   #16
I did have it tested and it is the type with asbestos. This is why I'm so concerned. It is not crumbling. You can walk on it and it feels very solid. Some of it did break when we took up the carpet that covered it---where the carpet was tacked down is where it cracked. We got suspicious after the fact and I had it tested. A good thick layer of regular old floor wax is a thought. I would have never thought of this.
I do want to say a big "Thank you" to everyone that is sending me advice. You've really helped calm my nerves a bit about this tile situation.
Gloriamb is offline   Reply With Quote
Old 07-15-2011, 06:43 AM   #17
DIY staff
Rewards Points: 7,174
I'd remove it if my daughter wanted a new floor---or cover it with another vinyl floor.
Any of the patches or levelers need something on top to protect them as they are all to soft for use as a finished floor.
If you don't you will be creating the very situation that you fear.---The patch will start to flake off and create dust--now the dust may contain bits of the old floor covering--bad.
Like I said before , With proper protection and technique the old flooring can be removed completely .
Then a proper floor covering can be installed.
Old 07-15-2011, 08:55 AM   #18
Thank you Mike. I am so confused. I really don't know what to do. Most web sites I go to say to not disturb the floor, just to cover it up. My plan was to cover it up with a layer of cement-leveler as an extra precaution and then put a new floor on top. What you said about the leveler making the situation worse puts me back to square one. It was on the back of my mind that a cement coat could actually soften or deteriorate the old tile or something and make matters worse.
Question about installing new vinyl flooring nschulz Flooring 2 06-18-2011 02:19 PM
remove grout from Allure vinyl flooring abkjr Flooring 2 08-02-2010 06:21 PM
Pulling up vinyl flooring, now what? loraxdh Flooring 9 10-24-2009 11:15 AM
asbestos problem with vinyl flooring darsunt Flooring 6 08-31-2007 01:47 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
