Covering/painting Stained Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 09:03 AM   #1
Toe
Question
Covering/painting stained linoleum
Hi. I am about to put my house on the market. I fixed everything up, then remembered that the laundry room's linoleum floor is stained.
There's nothing wrong with it: at one point long ago, I guess a washing machine spilled some water onto it, and the previous owner let it sit or something. In any event, it looks both yellowed and rust-stained. The stains do not come up with any cleaning solvent I have tried.
I don't really have the time or resources to pull out the laundry machines and replace the floor. So can anyone recommend a way to make it look nicer without making it look like I'm trying to hide something?
I have heard you can paint linoleum. Is that true? And if so, what kind of paint? I assume I don't want to use the flat acrylic I have been using on the walls...
Thanks!
Toe is offline   Reply With Quote
Old 03-28-2010, 08:08 PM   #2
water flows downhill
oarfish's Avatar
"Painting linoleum floor" That would be interesting.
I would just get a really nice floor mat and show the house that way.
oarfish is offline   Reply With Quote
white trim vs. wood stained nwalford Interior Decorating 17 02-28-2011 02:54 AM
Urine stained subfloor? - fix cornbread09 Flooring 1 08-11-2009 06:28 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
Linoleum Finish Question scubasteve882001 Flooring 1 02-12-2007 07:55 AM
