Old 06-30-2011, 11:28 PM   #1
Is covering inside concrete stairs with wood treads cool?
I'm in a townhome and the floors and stairs are concrete. I pulled up the carpet upstairs and on the stairway (6 steps, landing, 6 more steps). I am putting enginerred bamboo on the second floor and wanted to put wood over the concrete stairs. Is that safe or even doable? I can't find instructions anywhere. Thanks
HandyBeth is offline   Reply With Quote
Old 06-30-2011, 11:41 PM   #2
Tileguy
JazMan's Avatar
No! I don't recommend that.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
HandyBeth (06-30-2011)
Old 06-30-2011, 11:56 PM   #3
Will the glue not adhere? Is that why? Just keep it carpeted then?
Old 07-02-2011, 03:20 PM   #4
A pic of the steps would go a long way to helping form a recommendation.
HarryJ is offline   Reply With Quote
Old 07-03-2011, 10:30 AM   #5
Stuck in the 70's
Blondesense's Avatar
When you walk up a flight of stairs you unconsciously expect all the stairs to be the same.
Say you add a 1 inch tread to each stair. The bottom stair (measured against the floor) would be an inch taller than the rest, while the top landing would lose an inch. While this may not seem like a big deal, codes regarding this are strict for a reason. This creates a very real and very dangerous trip hazard.
Old 07-03-2011, 12:27 PM   #6
concretemasonry's Avatar
Since you apparently have already put in the flooring on the second floor, you have already created a "trip hazard" between the top tread and the second floor. This will be a code violation if caught during a resale, but you probably would have realized it by then if you use the stairs. Adding to the riser height will not be a problem. but there will be a difference since the first riser going up will be the one that is a little too much.
Dick
concretemasonry is offline   Reply With Quote
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 10:21 PM
Need help installing a wood transition onto concrete! oshkosh Flooring 3 02-02-2011 02:27 PM
wooden stairs on existing concrete stairs ThaboG Carpentry 7 08-06-2010 10:03 AM
Extension on Outside Concrete stairs i8kermit Building & Construction 1 07-28-2010 07:11 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
