Covering Concrete Steps - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2013, 10:17 PM   #1
freddyream's Avatar
Rewards Points: 12
Covering concrete steps
Hello everyone, I've done a ton of research and I think I've just completely confused myself even more. I have a living room that was once the garage. I just replaced the old carpet with laminate. I'm to the steps now, and they are concrete. What would be the best way to redo these steps? Tile? Wooden treads and risers? I need some advice from the pros. Thank you for any advice you may have.
Last edited by BigJim; 12-05-2013 at 07:08 AM. Reason: Map removed for security reasons
freddyream is offline   Reply With Quote
Old 12-05-2013, 06:59 AM   #2
Rewards Points: 13,746
Little late now, but the way I would have done it is demo the old steps and build new wooden ones.
There not even legal with that short step at the top forming a trip hazard and what looks like three different riser heights.
Old 12-05-2013, 04:30 PM   #3
Rewards Points: 3,630
You can increase the height of both tread's to eliminate the trip hazard that Joe mentioned,then face off the rest.
Canarywood1 is online now   Reply With Quote
Old 12-06-2013, 05:28 PM   #4
Rewards Points: 81
I don't think it works that way.
one cut is offline   Reply With Quote
The Following User Says Thank You to one cut For This Useful Post:
joecaption (12-07-2013)
Old 12-06-2013, 07:27 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Why not. Do you think that codes will come into the posters house and look around?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-06-2013, 08:16 PM   #6
Care to tell us why not???
If you have another solution,let us in on it.
Old 12-06-2013, 10:16 PM   #7
Rewards Points: 81
If you raise the top stair up to eliminate the tiny step. And you raise the first step the same amount, then you now have a first step that is too tall. The correct solution is to either ignore it or tear it out and re-do.
Old 12-07-2013, 10:37 AM   #8
You don't raise the first step to offset the trip hazard,divide the height by two and raise each step by that amount,then both steps are equal,and the small step is flush with the second step.
Old 12-07-2013, 10:46 AM   #9
Rewards Points: 81
I'll have to bow out of this one. I am confused by your description. Can anyone confirm that this makes sense.
Old 12-07-2013, 11:27 AM   #10
Sorry my mistake,should have said add half the height of trip hazard to bottom step and full height to top step.
Old 12-08-2013, 12:12 AM   #11
Rewards Points: 81
I don't want to sound rude but i still don't get it. Now your upper riser is taller than the lower one.
Old 12-08-2013, 09:55 AM   #12
Rewards Points: 126
Measure from the top to the bottom, split the difference and build a set of steps over those. Or just cover what you have, people get used to what they have.
Old 12-08-2013, 10:34 AM   #13
Gymschu's Avatar
Rewards Points: 846
Sure would have been easier to do the steps first before installing the new floor.
Old 12-13-2013, 11:53 AM   #14
Rewards Points: 274
It would be more appropriate.
alexjoe is offline   Reply With Quote
Old 12-13-2013, 11:53 AM   #15
Rewards Points: 274
I agree with you. It would be more appropriate.
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
re: re: refinishing concrete steps at the front door gramps416 Building & Construction 2 05-09-2011 06:13 AM
Adhering Wood steps to Concrete LouiseR36 Building & Construction 11 08-12-2010 04:39 PM
Concrete steps - Dressing up larryr20 Landscaping & Lawn Care 1 08-23-2006 01:24 PM
