covering concrete floor
Good Day to All, I need some advice on covering a concrete floor, with peel and stick tile,,,,,, I have an outside carport that I have recently re-errected an aluminum wall sun room on, the carport has a metal roof and open framing, I've used non vented vinyl soffit in the overhead of the room and am real satisfied with the look, but the floor,,,,, it's a non insulated slab 4-5 in thick with fiberglass impregnated 3500# concrete about 4 years old , smooth finish and clean, no grease or oil, I want to use peel and stick tile due to ease of installation, is there a coating I can use both as an adhesion promoter and sweat seal on the concrete, I've only seen the slab sweat once or twice in exterme weather, I don't want to install a sub floor, what do you think guys???
