Covering A Balcony - Flooring - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 03:10 PM   #1
Covering a balcony
I have a newly rebuilt balcony off of my master bedroom on the second floor of our tri-leval home. The deck is 5/8 tongue-in-groove plywood over 2" X 10" beams. I am looking into a polyurathane three step deck coating but I was also wondering if I can put down a hardybacker and then put down thinset with tile. What would give me the most durable deck for the money?
jimsquestions is offline   Reply With Quote
Old 07-03-2012, 03:44 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
This is outside balcony?....
If I was you I would consider doing it this way
TI Proboard lay it right on the joists and tile over it
http://www.tileyourdeck.com/
JetSwet is offline   Reply With Quote
Old 07-03-2012, 05:01 PM   #3
Renovations contractor
Bonzai's Avatar
Tiling an outside deck is nothing like tiling indoors and considerably more expensive to do than other forms of deck when done right.
What is below the balcony? Does it need to be watertight to protect an enclosed space below? If you are considering a roll on membrane then presumably you would be open to a sheet vinyl type product ... As much as I personally hate the look of them, they are very common here in BC as relatively affordable and last OK with our climate.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
How should i best decorate this balcony? Starjupitor Interior Decorating 12 06-01-2012 08:15 PM
Installing a ABS Pipe on a Balcony Donnythecat Building & Construction 13 03-18-2011 07:01 PM
balcony supports Thanatos Building & Construction 0 03-06-2011 04:51 PM
balcony delema onthelevel Carpentry 2 09-13-2008 10:53 AM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
