Old 01-22-2009, 05:59 PM   #1
Newbie Bill
Default A couple of Hardwood flooring questions
Hey Gang,
We are wanting to install Hardwood in our living/dining room and kitchen.
Is it OK to install the Hardwood over the vinyl flooring that is in the kitchen?
We aren't planning on touching our cabinets, but I think we may run into an issue with our dishwasher. With 3/4" hardwood, we may not get it back in there. And I don't know what my subfloor is, so if I need to add a layer, then I am really screwed.
Are there any words of wisdom out there on this topic?
drtbk4ever is offline   Reply With Quote
Old 01-22-2009, 09:01 PM   #2
best to consider a laminate in this case do to height issues. Doorways, trim, cabinets, dw and more.
Old 01-22-2009, 11:46 PM   #3
Tileman-Manufacturers rep
If you go over the vinyl chances are you will probably lock the DW in. You should remove the vinyl along with any 1/4" underlayment it's glued to. Remove both at the same time, leaving the vinyl glued to the underlayment.
The 3/4" hardwood can the nailed to the subfloor.
Dishwashers have adjustable feet. I would screw the feet in all the way, then shim the DW up as high as possible so that it can be pull out over the new floor, or install it on the new flooring.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 01-23-2009, 11:44 AM   #4
Newbie Bill
Jaz
Hey Jaz,
I checked my floor and it appears I have a 1/2" subfloor with what looks like about 3/8" that the vinyl is attached to.
This floor is over 2X10 joists spanning 12 feet between beams.
Is that a sufficient base for 3/4" hardwood? Because if it is, my dishwasher issues will go away as I am sure I'll have more than enough room, especially using the adjustable legs you mentioned.
Old 01-23-2009, 11:48 AM   #5
yes the subfloor is sufficient for a hard wood floor installation Be sure to nail into the joists.
Old 01-23-2009, 01:13 PM   #6
Newbie Bill
Whew, Thanks Bob. That is a load off my mind.
Old 01-23-2009, 04:03 PM   #7
Please double check and accurately measure the subfloor and underlayment. There is no jurisdiction that allows a single 1/2" plywood as "the" subfloor system. The minimum is 5/8" but it's usually 3/4". Years ago they did use a double subfloor system of 1/2 + 5/8". But that doesn't sound what you have.
Most underlayments for vinyl flooring are 1/4" luaun or similar. If that is what you have it has to go for sure. So measure the subfloor again and we'll see what you've got. You can drill a small hole to measure, or you may be able to read the specs from below. Do not install hardwood or anything for that matter on a single 1/2" plywood sub.
Jaz
Old 01-23-2009, 04:10 PM   #8
Jaz
We are assuming he has a 3/4 subfloor and 1/4 luan under the vinyl. But as you stated you need to be sure. Never seen only 1/2 over joists before but you never know.
Old 01-23-2009, 04:15 PM   #9
Newbie Bill
I'll check.
Old 01-23-2009, 11:04 PM   #10
Newbie Bill
Upon closer inspection, the subfloor is 5/8" throughout the house. Looks like vinyl is glued to 3/8" plywood on top of the 5/8".
So my plan is to remove the 3/8" plywood that the vinyl is glued to. Then install 3/8" plywood throughout.
That will give me a base of 1" for the Hardwood. The dishwasher is going to be TIGHT.
Old 01-24-2009, 12:17 AM   #11
Extreme DIY Homeowner
Scuba_Dave's Avatar
Why not just put the wood floor down on the sub floor?
Or put down 1/4" which in total will be more then the normal 3/4" sub floor
Old 01-24-2009, 11:20 AM   #12
Newbie Bill
Hey Scuba,
From what I understand, 5/8" floor under hardwood is a bare minimum. We would need a bit beefier subfloor, especially if we lay the flooring on a diagonal.
You are right that 1/4" will still be more than the ideal 3/4". It will likely come down to availability and cost.
Old 01-24-2009, 11:51 AM   #13
All 1/4" ply would do is raise the floor, It'll add almost no structural strength. And, if the 1/4" is luaun, it is specifically not recommended. If you need more stiffness, add 3/8" minimum, 1/2" or thicker would be better.
Jaz
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be showing you how we would estimate for our materials. Now, since I'm building this hutch primarily out of oak plywood, I went ahead and drew an oak plywood sheet, which would measure... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be laying out our kick plate. If we take a look at our drawing, we have this piece of wood down here at the bottom that will cover up our lower plywood piece and it will act like a... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be laying out our back piece. Now that we've rabbeted out our back and squared up the corners, we are ready to measure and lay out our back piece. Going back to our drawing, we have... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be laying out the bottom. Our bottom piece is going to be coming out of our sheet of plywood right next to our top piece. We are going to do the same thing in making that cut across... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be laying out the top. Now on my sheet of plywood, my top and bottom are going to come out of one side. I am going to go ahead and make these cuts first which go across the entire... Read More »
Installing Hardwood questions myphaykename Flooring 10 01-23-2009 10:48 PM
questions about 20 year old hardwood flooring uper104 Flooring 2 10-09-2007 12:54 PM
hardwood flooring over sheet vinyl floor chrish Flooring 0 09-10-2007 09:13 PM
Hardwood Flooring is one of the Most Important Design Elements in your Home Decor doctorhouse Flooring 1 12-22-2005 10:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
