-   -   A couple of Hardwood flooring questions (http://www.diychatroom.com/f5/couple-hardwood-flooring-questions-36571/)
drtbk4ever 01-22-2009 04:59 PM
Hey Gang,
We are wanting to install Hardwood in our living/dining room and kitchen.
Is it OK to install the Hardwood over the vinyl flooring that is in the kitchen?
We aren't planning on touching our cabinets, but I think we may run into an issue with our dishwasher. With 3/4" hardwood, we may not get it back in there. And I don't know what my subfloor is, so if I need to add a layer, then I am really screwed.
Are there any words of wisdom out there on this topic?
Bob Mariani 01-22-2009 08:01 PM
best to consider a laminate in this case do to height issues. Doorways, trim, cabinets, dw and more.
JazMan 01-22-2009 10:46 PM
If you go over the vinyl chances are you will probably lock the DW in. You should remove the vinyl along with any 1/4" underlayment it's glued to. Remove both at the same time, leaving the vinyl glued to the underlayment.
The 3/4" hardwood can the nailed to the subfloor.
Dishwashers have adjustable feet. I would screw the feet in all the way, then shim the DW up as high as possible so that it can be pull out over the new floor, or install it on the new flooring.
Jaz
drtbk4ever 01-23-2009 10:44 AM
Jaz
Hey Jaz,
I checked my floor and it appears I have a 1/2" subfloor with what looks like about 3/8" that the vinyl is attached to.
This floor is over 2X10 joists spanning 12 feet between beams.
Is that a sufficient base for 3/4" hardwood? Because if it is, my dishwasher issues will go away as I am sure I'll have more than enough room, especially using the adjustable legs you mentioned.
Bob Mariani 01-23-2009 10:48 AM
yes the subfloor is sufficient for a hard wood floor installation Be sure to nail into the joists.
drtbk4ever 01-23-2009 12:13 PM
Whew, Thanks Bob. That is a load off my mind.
JazMan 01-23-2009 03:03 PM
Please double check and accurately measure the subfloor and underlayment. There is no jurisdiction that allows a single 1/2" plywood as "the" subfloor system. The minimum is 5/8" but it's usually 3/4". Years ago they did use a double subfloor system of 1/2 + 5/8". But that doesn't sound what you have.
Most underlayments for vinyl flooring are 1/4" luaun or similar. If that is what you have it has to go for sure. So measure the subfloor again and we'll see what you've got. You can drill a small hole to measure, or you may be able to read the specs from below. Do not install hardwood or anything for that matter on a single 1/2" plywood sub.
Jaz
Bob Mariani 01-23-2009 03:10 PM
Jaz
We are assuming he has a 3/4 subfloor and 1/4 luan under the vinyl. But as you stated you need to be sure. Never seen only 1/2 over joists before but you never know.
drtbk4ever 01-23-2009 03:15 PM
I'll check.
drtbk4ever 01-23-2009 10:04 PM
Upon closer inspection, the subfloor is 5/8" throughout the house. Looks like vinyl is glued to 3/8" plywood on top of the 5/8".
So my plan is to remove the 3/8" plywood that the vinyl is glued to. Then install 3/8" plywood throughout.
That will give me a base of 1" for the Hardwood. The dishwasher is going to be TIGHT.
Scuba_Dave 01-23-2009 11:17 PM
Why not just put the wood floor down on the sub floor?
Or put down 1/4" which in total will be more then the normal 3/4" sub floor
drtbk4ever 01-24-2009 10:20 AM
Hey Scuba,
From what I understand, 5/8" floor under hardwood is a bare minimum. We would need a bit beefier subfloor, especially if we lay the flooring on a diagonal.
You are right that 1/4" will still be more than the ideal 3/4". It will likely come down to availability and cost.
JazMan 01-24-2009 10:51 AM
All 1/4" ply would do is raise the floor, It'll add almost no structural strength. And, if the 1/4" is luaun, it is specifically not recommended. If you need more stiffness, add 3/8" minimum, 1/2" or thicker would be better.
Jaz
