Countersinking Screws Into Hardibacker - Flooring - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 11:24 PM   #1
Countersinking screws into Hardibacker
Does anybody know of a "dimpler" like drill attachment which allows the user to quickly and correctly countersink a screw into Hardibacker?
The dimplers I see advertised are phillips screw drives and mainly for drywall or wood. The recommended screws for Hardibacker have the square (Robertson?) drive heads, which are stronger and easier to drive without stripping than the Phillips drive.
I usually overdrive or underdrive my screws on the first attempt...When I underdrive one and then try to redrive it in further, I end up overdriving it...So to avoid overdriving, I usually end up manually driving the screw in by hand with a ratchet drive...Too time cunsuming and tough on the hands.
Can anybody offer some suggestions?
Thanks all!
billyg is offline   Reply With Quote
Old 09-25-2011, 11:18 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WOW!!! You are w-a-a-a-a-y overthinking this.
What brand of thinset are you using to install the Hardibacker?
Old 09-27-2011, 08:34 AM   #3
I have always had the same problem, and had to drive some of them by hand to get them recessed. Now I'm using an impact driver, and it works real well.
Reb101 is offline   Reply With Quote
Old 09-27-2011, 01:41 PM   #4
Curious as to why you would ask what brand of thinset he is using?
misguydead is offline   Reply With Quote
Old 09-27-2011, 02:54 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I have my reasons.
Old 09-27-2011, 09:40 PM   #6
does it have to with its adhesion factor?
Old 09-27-2011, 09:44 PM   #7
at some point soon - I will be doing the same thing ... ( installing hardibacker) ... just looking for suggestions to make sure it goes smoothly ... ???
Old 09-27-2011, 10:09 PM   #8
Rewards Points: 558
Thanks all!
On your drill you should have tork settings 1-12. Next get a scrap piece of hardibacker and a piece of the underlayment. Now set your drill using the numbers and drill into your scrap until you have the right setting to countersink the screw to the desired depth.
epson is offline   Reply With Quote
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
uneven seams with hardibacker after thinset and screws wpeckler Tiling, ceramics, marble 0 03-03-2011 02:25 PM
Can I use deck screws with Hardibacker? spaceman spif Kitchen & Bath Remodeling 10 10-26-2010 03:11 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
