Old 03-27-2012, 11:44 PM   #1
Correction for tiling an unlevel floor
I am planning on installing mosaic marble (floor) and 3x6 subway tile (wall) in a 36 sq ft half bath. At one point this was a back porch and is pitched. I am out of level by 1&1/4 inches across the 64 in room east to west. The subfloor is solid and flat, I was about to fix my hardiboard when I realized how out the floor was. The height is 82 in so I don't have a lot of elevation to work with. I see my options as 1. Make up the difference in the first layer of subway tile, which leaves one side of the room with a first layer of only 1&3/4 on one side and cutting the north wall first layer on an angle to transition from E to W or 2. rip up the subfloor and somehow level it with shims or something.
I welcome input on how noticeable option 1 is, how to implement option 2 or other miracle fixes
JPT1 is offline   Reply With Quote
Old 03-28-2012, 06:15 AM   #2
Super Moderator
Pull off the subfloor and sister in some level floor joists---
Or use deck mud and self leveling compound---http://www.diychatroom.com/f80/mud-what-77763/
Old 03-28-2012, 08:51 PM   #3
Thanks, you got me away from the tlle remedy.
I couldnt open the link you sent.
I can't take up the floor for a few reasons. It seems like my best bet is the leveling compound. If I use this can/does one fasten hardiebacker on top or tile on the leveling cement? Are you aware of any depth limitations on leveling compounds, what is the thickest and thinest I could go? Lastly is it ok to use this stuff in a stepwise approach starting at the low end and doing several applications to work up to the high end?
John
Old 03-29-2012, 07:00 AM   #4
Super Moderator
My computer is FUBAR---sorry---go to the tiling section--that is a 'sticky' at the top--Bud Cline wrote it,well worth reading.
Tile is set right onto the Self leveling compound,no need for a backer--
Add sand to the deep areas ---stretches the product and makes it stronger----
If you use deck mud--pack the deck mud on top of a wet layer of modified thinset---that will aid in bonding the deck mud to the subfloor---
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
