Cork And Water-poof Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 09:01 AM   #1
Cork and water-poof underlayment
For the sake of noise reduction, I read somewhere that you can put down cork on top of the waterproof underlayment (I'm installing on a concrete floor above grade). I was also told NOT to do this.
Anyone in the know, is there a reason why I should not put down cork over the underlayment?
Thanks.
gmhut is offline   Reply With Quote
Old 08-03-2009, 07:59 PM   #2
Two layers of underlayment? Why not just buy one product that is a moisture barrier and reduces noise?
Tess is offline   Reply With Quote
Old 08-04-2009, 08:50 AM   #3
One layer that is moisture barrier and padding from the manufacturer, one more dense layer of cork to reduce the "tap, tap" sound, typical of laminate flooring.
Old 08-04-2009, 11:21 AM   #4
In my opinion, that sounds like too much padding and might cause problems with the floor. There are 3-in-1 underlayments that have the pad, moisture barrier, and noise reduction like Floor Muffler, Acoustichoice, etc.
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 05:11 PM
Using baseboard hot water in a radiant floor?? tpagel HVAC 5 03-10-2008 09:33 AM
Cork on a deck?? bkrafty Flooring 2 05-21-2007 11:58 PM
Cork Floors flysndoc Flooring 10 02-17-2007 04:50 PM
