Cork Underlayment For Nailed 3/4" Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 09:55 PM   #1
Cork underlayment for nailed 3/4" hardwood floor
I would like to decrease noise downstairs and plan to use 1/8" cork lay down on 3/4" plywood. After I will nail down 3/4" hardwood floor.
I'm concern if cork and parquet will create any squeaking noise.
Should I use paper above cork?
Does anyone use 1/4" cork for nailed down floor? Will it work?
Does it all make any sense?
Since joints are not even and it is a lot of work to make it even I don't want to use floating floor.
Lubko is offline   Reply With Quote
Old 06-10-2010, 10:50 AM   #2
Handyman
Rewards Points: 512
What do you mean this? Any pics? Even though hardwood is nailed, the floor still needs to be flat.
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
Lubko (06-10-2010)
Old 06-10-2010, 11:02 AM   #3
It will be flat enough but not as floating floor 1/8 per 10', plus I'm skeptical about "feeling" floating floor.
Old 06-11-2010, 06:35 AM   #4
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Squeaks
The cork underlayment will eliminate squeaks. I'm using it on top of every layer. Beams, ceiling boards, then another beam and then the top floor. Cork in between each. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
The Following User Says Thank You to shumakerscott For This Useful Post:
Lubko (06-11-2010)
Hardwood floor is buckling again Kerm Flooring 1 05-07-2010 05:35 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Cork floor in Finished Attic - Old Subfloor thriftstorejedi Flooring 2 05-14-2008 05:27 PM
