Cork Underlayment And Laminate Advice - Flooring - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 11:18 PM   #1
Question
Cork Underlayment and Laminate Advice
Happy New Year, all!
I have a 100-year old home with the original hardwood floors. The second floor generates a bit of noise and I'm looking for a quick, inexpensive fix. It is currently an apartment.
The second floor is currently tile (kitchen and bathroom), original hardwood (bedroom and hallway) and parquet (living room). The original hardwood is in pretty good shape and I'd like to save it (at least for now). I'm not sure why the living room is parquet but it is sitting on plywood (1/4 I believe) that is on top of the original subfloor (1/4" or 3/8" planks). The parquet is approximately 1/8" higher than the original hardwood.
The original hardwood and parquet floors are level and do not appear to have any serious dips.
I would like to cover the original hardwood and parquet in a laminate or engineered floor. Ideally, cork underlayment would be used to soften the floor and provide some soundproofing between the first and second floors (I realize this won't be perfect).
So here's my plan:
- cover existing hardwood floor and parquet with 1/4" cork underlayment (floated, not glued)
- lay another layer of cork underlayment (1/8" thick) on top of the existing hardwood floor to level the surface between the hardwood and parquet floors
- lay 12mm or 13mm laminate (or 3/8" engineered hardwood) floor on top of the cork (floated, not glued or stapled)
My questions are:
1) Is there any issues that would arise from laying the second layer of cork on top of the first?
2) Would it be more prudent to only have one layer of 1/4" cork underlayment throughout and simply install a threshold where the 1/8" difference in height occurs?
I'd love to hear anyone's opinions or previous experience. It is a rental property so I'd like to get the most bang for my buck with regards to both appearance and soundproofing.
Cheers!
Drew
SparksTO is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 01:18 AM
Soundproof underlayment: 1/4 in cork, poly, and a brand underlayment on top? Ghoren Flooring 2 05-23-2012 12:32 PM
Laminate Floor Underlayment Question hurt138 Flooring 4 11-08-2011 12:30 PM
Underlayment under laminate sanramonvalleyfitness Flooring 4 12-31-2008 08:56 PM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 01:24 AM
