Cork Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 12:25 AM   #1
Rewards Points: 56
Cork Underlayment
In a condo on the second floor. Ordered 1/4" cork underlayment to put over what looks like plywood and Luan subfloor (1/4"Luan is on top). I'm going to order a floating Laminate floor. It is my understanding that the cork underlay doesn't need to be glued down for this type of flooring. My question is, does the cork underlay need to be installed flush with the walls, or should I leave a 1/8 to 1/4" space around the perimeter for the cork underlay? I'm trying to optimize the sound deadening properties.
diyGK is offline   Reply With Quote
Old 03-31-2013, 05:16 AM   #2
Rewards Points: 13,300
I just staple it down. do not need many, just enough to keep it from moving around when installing the floor.
Make sure the staples are just below the surface, a light tap with a hammer will do.
If your using the rolled stuff, unroll it, cut to length and flip it over.
No need for a gap.
oh'mike (03-31-2013)
Old 03-31-2013, 10:09 AM   #3
Rewards Points: 222
just wondering. what was on the floor ? carpet ?
Fix'n it is offline   Reply With Quote
Old 03-31-2013, 05:44 PM   #4
Rewards Points: 56
Yes, carpet.
Question: for an isolation barrier, it is my understanding that I cut a 2" strip and glue it to the wall. Do I then unroll and butt the cork underlayment to this barrier? When the floating laminate floor is installed, do I just cut the isolation barrier to the level of the floor and install my trim?
Old 03-31-2013, 08:32 PM   #5
Rewards Points: 222
well, i feel bad for those that live below you then. they are going to hear nearly every step you take, perhaps every conversation and tv show, music also.
Old 03-31-2013, 08:38 PM   #6
Rewards Points: 56
Even with cork uderlayment?
Old 03-31-2013, 09:04 PM   #7
Rewards Points: 222
it sounds like you have joists. i used to live in a condo that had flexi-core with cement over it. and i could still hear some things. but not so much in the rooms that had carpet(the unit above).
Old 03-31-2013, 09:20 PM   #8
Rewards Points: 56
Yea. This condo unit is so poorly "sound proofed" that I can hear my neighbors sneeze. At night I need
to play a low frequency sound from a boom box to drown out the guy below me (snoring). So I consider my neighbors fortunate that I am at least investing in cork underlay. I'm also going to invest in 1/2" cork for the bedroom with the hopes of not needing to blast an 85hz track all night to fall asleep.
Anyway, I'm hoping that if I install a sound isolation barrier around the perimeter and 1/4" cork under the floating laminate, that I'd get some type of improvement since the carpet I had was cheap and the pad was missing in areas. The floors squeaked like hell w the carpet, so probably not going to be much difference to my neighbor below.
Old 03-31-2013, 09:48 PM   #9
Rewards Points: 222
it sounds like you really don't want carpet, correct ?
Old 03-31-2013, 10:02 PM   #10
Rewards Points: 56
Correct. Dislike carpet.
Old 03-31-2013, 10:21 PM   #11
Rewards Points: 222
perhaps get carpet just for your bedroom. that would really help with the snoring issue. and then whatever you want for the rest of the unit.
afa the cork. idk what that would do. i am sure it will help, but idk how much.
Old 03-31-2013, 10:30 PM   #12
Rewards Points: 56
Thanks. I actually still have the carpet in the bedroom and can hear the snoring loudly. 1/2" cork is supposed to have incredible sound dampening properties......worse case....I'll install the cork in the bedroom and then put a pad and carpet over it.
Old 03-31-2013, 10:42 PM   #13
Rewards Points: 222
ok. well, good luck with that. and let us know how it turns out. we like to hear results.
Old 04-02-2013, 10:40 PM   #14
Rewards Points: 56
Been doing some research and there seems tube conflicting views on how cork underlayment should be installed. Some sources say to cut and glue a 2" isolation barrier around the perimeter and lay the cork sheets butted against this barrier: http://www.crescenthardwood.com/pl/bostik/cork.pdf
Other sources, like Lumber liquidators recommend leaving a 1/4" -1/2" expansion gap. Anyone have real world experience on this? My gut tells me to follow the 2" iso barrier and butt the cork against it
Cork Underlayment and Laminate Advice SparksTO Flooring 0 01-02-2013 12:18 AM
Soundproof underlayment: 1/4 in cork, poly, and a brand underlayment on top? Ghoren Flooring 2 05-23-2012 01:32 PM
vinyl planks over cork underlayment mashutka Flooring 0 03-25-2010 11:07 AM
Help for Tile install. Cork underlayment? andy1908 Flooring 8 06-04-2009 03:54 PM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 04:17 PM
