Cork Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 02:25 PM   #1
Cork Underlayment
Do you know of a supplier of 6ml cork underlay to be used for the installation of a tile floors over a heated wire floor system on a concrete slab subfloor?
I have an existing floor composed of 2 - 5/8 plywood materials, which was previously carpeted using a carpet adhesive. The carpet was removed, however some of the carpet glue remained on the plywood subfloor. If I plan to install the cork underlayment on the subfloor is is necessary to remove the remanants of the carpet adhesive. The remaining carpet adhesive is stubbornly attached to the subfloor. I plan to install the cork underlayment using an urethan adhesive.
carpal is offline   Reply With Quote
Old 08-20-2011, 03:08 PM   #2
DIY staff
Rewards Points: 7,174
Sorry--I just run down to my local tile supplier and pick it up.
Where do you live? There might be a tile supplier that has it.
Old 08-20-2011, 03:10 PM   #3
woodman58's Avatar
Supplier is Amcork.com. You can glue it over the addhisive.
woodman58 is offline   Reply With Quote
Old 08-20-2011, 09:35 PM   #4
Cork Underlayment
Rolls or Sheets?Widgetco.com have the sheets with free shipping when u spend over $20.Homedepot.com has the 200 ft. 6mm rolls for $.59 sq ft & free shipping
lorra is offline   Reply With Quote
Old 08-21-2011, 07:42 AM   #5
woodman58's Avatar
I prefer rolls. This is just a personal choice. Look at the layout of the room and see which one will be easier to lay out. Before buying the cork, find out the density. Cork can vary in from manufacturer to manufacturer. Find one with between 10 to 12 pound density. I prefer 1/4 inch over 1/8 inch.
tile on cork underlayment rba4sra Tiling, ceramics, marble 0 05-20-2011 12:52 PM
vinyl planks over cork underlayment mashutka Flooring 0 03-25-2010 11:07 AM
Cork as underlayment for Tiles IloveMuenchen Flooring 5 11-22-2009 01:59 PM
Help for Tile install. Cork underlayment? andy1908 Flooring 8 06-04-2009 03:54 PM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 04:17 PM
