Cork Under Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 06:14 PM   #1
Cork under laminate
Purchasing the laminate from Costco for 2 bedrooms. One of the bedrooms is over a garage and I would like to add a cork underlayment to help deaden the sound from the garage. We put this down when we put in a cork floating floor and just lay 2x3 pieces. Can this be done or is it overkill since the laminate already is padded. Also the instructions for the harmonics wants a vapor barrier. Why? It's on the second floor, so is that really necessary also.
Thanks for your help!
Rustigger is offline   Reply With Quote
Old 09-20-2010, 01:00 PM   #2
floor_whore
Send a message via Yahoo to Aaroncarpet
I really like cork, But I like it as a finished floor and stained...to me it sounds over kill...I would think you would do better by putting accoustacal tiles on the garage ceiling....This is only my opinion, but one concern maybe having too much cushion underneath the laminate....also maybe look into an alternative method for suspending you door opener...
A hundred yards a day (residential), keeps the bill collectors away....
Aaroncarpet is offline   Reply With Quote
Old 09-20-2010, 01:54 PM   #3
Maybe I was unclear. The garage under this room is completely finished. The ceiling is already drywalled with insulation. The house was built like this. We are replacing carpet. Was just wondering if we could add more soundproofing by adding a layer of cork between the laminate and subfloor. We did this in another room but the floor did not have a preattached pad, the one we are now looking at does.
Old 09-20-2010, 02:48 PM   #4
Soundproofing Guy
Rewards Points: 158
If you are guarding against airborne noise, then a pad / cork / rubber isn't advised since it creates it's own resonance. Any compressible layer will do this in between rigid surfaces (the subfloor and the engineered floor. If you are worried about airborne sound, rather than impact (footfall) noise, then simply add mass like plywood, and damp with a damping compound.
If you have impact noise from footfall, then this compressible layer is a necessary evil. Cork isn't used as much these days as it is an organic material susceptible to mold. It's also quite thin, and any thin underlayment won't work as well as a thicker one.
Ted White is offline   Reply With Quote
The Following User Says Thank You to Ted White For This Useful Post:
Rustigger (09-20-2010)
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Laminate to cork? tracyanne Flooring 3 02-24-2010 11:01 AM
Bamboo vs hardwod vs cork vs laminate E-ROCK Flooring 10 03-19-2008 12:45 PM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 09:05 PM
