Old 10-26-2009, 12:27 PM   #1
Cork flooring in a basement
Anyone had any experience with cork flooring in a basement? I'm considering installing the click together type floating floor tiles over a concrete floor in a basement. The manufacturer recommends a vapor barrier but that's it. I'm worried about installing something expensive over concrete. Is installing such a product in the above mentioned way a mistake or am I good to go?
trosenda is offline   Reply With Quote
Old 10-26-2009, 01:40 PM   #2
A basement is an ideal location for a cork flooring. It is an engineered product designed for this application. Make sure the vapor barrier is installed properly, no holes/gaps anywhere, all seams taped.
Consider a moisture test on the floor. This will tell you if you have a bad moisture problem that could need more than just a vapor barrier.
JK Floors is offline   Reply With Quote
Old 10-26-2009, 04:57 PM   #3
sdsester's Avatar
Excellent choice! It is naturally insulating and soundproof. I have specified the flooring from this company and the clients always seem happy. Just in case you need more options.
http://www.duro-design.com/
sdsester is offline   Reply With Quote
Old 10-27-2009, 06:31 PM   #4
Soundproofing Guy
Cork isn't soundproof.
Ted White is offline   Reply With Quote
Old 10-27-2009, 08:06 PM   #5
sdsester's Avatar
Ooops. Meant that it has sound insulating qualities harder floors do not.
Old 10-28-2009, 11:08 AM   #6
Soundproofing Guy
That's true.
Tags
basement, cork, flooring
Cork flooring reviews SillyGoose Flooring 12 08-20-2011 12:28 AM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 09:05 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
