Old 12-05-2011, 03:17 PM   #1
Cork Flooring in the basement
Hi
We are currently finishing the basement at the cottage.
Part of the job will be flooring
We are thinking about Cork Flooring
Will I have a problem putting a slate pool table on it? Will the table crush or sink into the flooring?
BrendaL is offline   Reply With Quote
Old 12-06-2011, 06:51 AM   #2
Doer of Many Things
poppameth's Avatar
Glue down or floating floor?
poppameth is offline   Reply With Quote
Old 12-06-2011, 08:36 AM   #3
Probably floating
Glue down is way too much work for and area that is approx 1200 sft
Old 12-07-2011, 06:48 AM   #4
Doer of Many Things
poppameth's Avatar
I don't think any floating floor is really a good idea if you are putting that kind of weight on it. The cork itself would bounce back from indentation pretty well if you are careful not to drag the pool table across it. Lift it instead. Floating floors are no suppose to have too much focused weight on them though so they can move properly. A pool table would pin it in place.
The Following User Says Thank You to poppameth For This Useful Post:
BrendaL (12-07-2011)
Old 12-07-2011, 08:12 AM   #5
Thanks Poppa Meth
I'll take that into consideration when we get to the point of actually purchasing the flooring.
I was thinking of Maybe cutting the flooring around the legs so that that the table actually sits on the cement floor instead of the floating floor
Think that would work?
Old 12-07-2011, 09:23 AM   #6
If you did that it would look like poop and you would have to border it with some form of trasition strips to allow movement of the flooring.
And what do you do with the holes when there's no longer a pool table there?
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Basement flooring questions momto4kids Flooring 1 10-15-2011 05:08 PM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 09:05 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 03:38 PM
