Cork Floor On Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 11:05 AM   #1
cork floor on slab
Hi I am looking into getting cork flooring for the entire first floor which sits on a slab and have a few questions
1) Which type of cork flooring is better for a slab glue down tiles or floating floor style?
2) Do I need to install Ditra for either of these types of cork flooring? IF not do I need any type of subfloor and if so what?
3) What type of vapor barrier is recommeded?
By the way I am covering approx 600 sqare feet with the cork flooring.
Thanks in advance for your help and advice
Alison
alihawk is offline   Reply With Quote
Old 06-27-2010, 12:58 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't "glue-down" floating floors.
Why? DITRA is used for isolating rigid ceramic and stone tile floors. Where did you get that idea?
What does the floor covering manufacturer recommend?
ALWAYS follow the recommendations of the product manufacturer.
XXX
Old 06-27-2010, 01:02 PM   #3
I know you don't glue down floating floors but cork come in glue down tiles and floating floor options so I was wondering which would be better for a slab
Old 06-27-2010, 01:07 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK gotcha. In that case had you used a comma in the proper location the sentence would have been more readable and understandable.
Which type of cork flooring is better for a slab, glue down tiles or floating floor style?
In concrete there could be moisture issues that would effect a glue-down installation. Therefore, a floating floor may be the smarter choice. What is the moisture content of the concrete? What did your moisture tests results say?
XXX
Old 06-27-2010, 05:42 PM   #5
Handyman
Rewards Points: 512
Cork flooring is a great product, as is bamboo. The drawback is the cost but since you have some, use it. I used to use the latex contact for decorative walls and some floor detailing but, as Bud said, on a concrete floor wouldn't be advisable. If you are installing the lock and load cork, buy the regular underlay. Have you got pics of the underside so that we are sure of what you have?
canadaclub is offline   Reply With Quote
Cork flooring reviews SillyGoose Flooring 12 08-19-2011 11:28 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 08:05 PM
