Old 10-16-2007, 10:59 AM   #1
Cork Floor Installation
I searched the forum for my question, but didn't have much luck...maybe my question is for ultra-novices!
I'm installing a 4mmx 300mm x 600mm Lisbon Cork Sunset glue-down floor this evening. The room is less than 20 sq.ft. and the tiles will be placed directly on the subfloor.
My question is this- I've never glued down a floor and am wondering exactly how to do it? Do I place the adhesive on both the tile and the floor? Do I need to get complete coverage on every inch of the floor and/or tile with the adhesive? How thick should the adhesive be applied?
The adhesive I bought was one from HD for laminate wood or parquet floors.
Thanks!
frankthetoad is offline   Reply With Quote
Old 10-16-2007, 12:45 PM   #2
I'd read the adhesive. Probably you trowel it onto the sub-floor with a notched trowel, doing a few square feet at a time, then applying tiles to that area, and moving on. How large an area depends on how long the glue can be open on the floor before it flashes.
NateHanson is offline   Reply With Quote
Old 10-17-2007, 02:06 PM   #3
Floorwizard's Avatar
Some cork adhesive actually have you adhere the floor AND the tiles, then place on the floor.
just like laying a Formica top with contact cement.
Floorwizard is offline   Reply With Quote
Old 10-17-2007, 11:41 PM   #4
Tileguy
JazMan's Avatar
I don't think so. You wouldn't want to install any multiple piece covering that way. The correct adhesive is a multipurpose latex or even a cove base adhesive is fine. Work backwards and allow to dry 24 hours before stepping on it.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Use cork tiles under basement carpet Tech7 Flooring 2 03-20-2011 08:15 PM
Cork on a deck?? bkrafty Flooring 2 05-21-2007 11:58 PM
Installing Cork Flooring tjshoup Flooring 2 03-01-2007 12:11 AM
Cork Floors flysndoc Flooring 10 02-17-2007 04:50 PM
