-   -   Cork Floor Installation (http://www.diychatroom.com/f5/cork-floor-installation-12438/)
frankthetoad 10-16-2007 10:59 AM
I searched the forum for my question, but didn't have much luck...maybe my question is for ultra-novices!
I'm installing a 4mmx 300mm x 600mm Lisbon Cork Sunset glue-down floor this evening. The room is less than 20 sq.ft. and the tiles will be placed directly on the subfloor.
My question is this- I've never glued down a floor and am wondering exactly how to do it? Do I place the adhesive on both the tile and the floor? Do I need to get complete coverage on every inch of the floor and/or tile with the adhesive? How thick should the adhesive be applied?
The adhesive I bought was one from HD for laminate wood or parquet floors.
Thanks!
NateHanson 10-16-2007 12:45 PM
I'd read the adhesive. Probably you trowel it onto the sub-floor with a notched trowel, doing a few square feet at a time, then applying tiles to that area, and moving on. How large an area depends on how long the glue can be open on the floor before it flashes.
Floorwizard 10-17-2007 02:06 PM
Some cork adhesive actually have you adhere the floor AND the tiles, then place on the floor.
just like laying a Formica top with contact cement.
JazMan 10-17-2007 11:41 PM
I don't think so. :no: You wouldn't want to install any multiple piece covering that way. The correct adhesive is a multipurpose latex or even a cove base adhesive is fine. Work backwards and allow to dry 24 hours before stepping on it.
Jaz
