Cork Floor In Finished Attic - Old Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-13-2008, 01:59 PM   #1
Question
Cork floor in Finished Attic - Old Subfloor
I recently bought a 1949 cape cod, and when we ripped the hideous pink carpet off the second floor, we found asbestos tiles underneath. We had a company come in and professionally remove the tiles, but in order to get all the mastik up, they had to remove the plywood subfloor to which the tiles were attached.
Underneath the 3/8" plywood we found an OLD (probably original) wooden plank subfloor running the length of the room.
We have ordered new cork click flooring to install, but have been told we cannot (at least should not) install the cork directly over these planks, especially as they run the length of the room (the direction we want the cork floor to run). We have been told if we put down some plywood, we'd be OK to lay the cork on top of that.
Now, the question is...
1) Is this correct? All we need is a layer of plywood on top of the planks?
2) If so, how thick does it need to be? The existing subfloor is not perfectly flat, but not horrible, and is solid as a rock. Can I get away with just laying sheets of luaun? Or does it need to be thicker/stronger?
Many thanks in advance for any insight!!
thriftstorejedi is offline   Reply With Quote
Old 05-13-2008, 10:08 PM   #2
Floorwizard's Avatar
Any floating floor can be run in any direction.
as long as the floor is flat.
Floorwizard is offline   Reply With Quote
Old 05-14-2008, 05:27 PM   #3
That is what I thought as well. Thanks.
julio333 is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
finished attic floor? ponch37300 Building & Construction 7 02-28-2008 07:12 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 08:05 PM
